Car won't Start
Old Mar 22, 2003 | 03:22 PM
KWKSLVR's Avatar
S.E. Region Moderator
Angry Car won't Start
Ok, we thought that naturally it was the starter, so I ordered up a CVR from Jegs. Both (stock and new) test fine. We bypassed the clutch switch (which tested fine as well) and it still won't start.
We even tried charging the battery to make sure it wasn't low voltage, but that wasn't the case either. We're out of idea's. Anyone have any?
Old Mar 22, 2003 | 03:28 PM
KWKSLVR's Avatar
Also: Solenoid Wire had 3 volts and the main had 12 on both starters.
Old Mar 22, 2003 | 03:38 PM
joeSS97's Avatar
Bad ground wire.Check all your grounds off the engine.
Old Mar 22, 2003 | 04:18 PM
See if you get 12v on the the purple starter wire when the key is turned to START.
Old Mar 22, 2003 | 05:09 PM
KWKSLVR's Avatar
Well, we think we've narrowed it down, theres a crimp in the wire that runs from the starter solenoid to the starter. Is there anything in between?
Old Mar 22, 2003 | 05:20 PM
Brady's Avatar
I think there's a relay under the dash on the passenger side. I'm not sure of it's function, but the purple wire comes out of it. In fact if I remember right it has like a small 18 gauge yellow/black wire and a bigger brown wire that goes to the body control module. The big yellow wire comes from the neutral safety (A4) and the purple runs to the solenoid to start the car..
just a thought
...Brady
Old Mar 24, 2003 | 03:45 PM
BUBBA's Avatar
I know you said you charged the battery but, if the battery is really low, has a dead cell (plainly is no good) that is the very first place you need to double check.
Batteries usually are mostly to fault.JMHO
Old Mar 24, 2003 | 07:06 PM
KWKSLVR's Avatar
We're 99% sure its the pass-key. My spare key is on its way down now.
On further note: http://web.camaross.com/forums/showt...807#post742807
Old Mar 24, 2003 | 07:53 PM
badass383's Avatar
If the pass key were the problem the security light would be on or blinking.
Bypass it with a resistor at the connector at the bottom of the steering column.
Use the same value as the key resistor is. Within 10 + or -
Old Mar 24, 2003 | 07:57 PM
ponykiller z28's Avatar
Talking
be careful ! you might have a killer after you! thats usually why it won't start
couldn't resist
Old Mar 24, 2003 | 08:12 PM
KWKSLVR's Avatar
The light is on, we just didn't notice it (figures). With my SES Light on all the time (exhaust), yellow from that side of the car just blends in naturally
Old Mar 25, 2003 | 05:43 PM
KWKSLVR's Avatar
Ok, the Key's test fine, both are 931 ohms. The resistance @ the connector is 1600-1700 but it won't remain constant. So I guess I should replace the switch harness?????
Old Mar 25, 2003 | 06:37 PM
Or just stick a resistor close to 931 ohms into the connectors going back to the PassKey module and drive on. At least it would be good for a test.
You could also try to clean the key cylinder with whatever you can, too.
Old Mar 25, 2003 | 11:54 PM
KWKSLVR's Avatar
Man, I don't even know how to find that many resistors . Thats my project for some time this week. If that doesn't fix it, I'm pushing her off a cliff .
Old Mar 26, 2003 | 09:33 AM
KWKSLVR's Avatar
So was yours in the 1130 ohms (acceptable range 1085-1195) category?
Meaning that mine is in the 887 ohms (acceptable range 850-942) category? So which resistors would i need? I have no clue how electrical BS works
Do I need like a 4.7 and a 2.2 or like a 4.7 and two 1's for each "bank"?
