Car Won't Start
Just got my car back together on Friday (ported heads, LT Headers, LT4KM). Ran it for a day with open headers (WOW - it hauled). Got the y-pipe installed on Saturday. Everything was working fine except the exhaust was rubbing a bit under hard acceleration.
Drove it yesterday and began to get some stumbling. It even stalled once. Got to a friends house, turned it off and then tried to start it. It was turning over but not quite catching. I came back a little later and it would turn over but wasn't even close to starting.
The car usually is a little hard to start, but this weekend it took several seconds for it to start.
So I am thinking it is maybe the fuel pump. When it was stumbling yesterday, I would put the clutch in and rev it with no problems. But when under acceleration or climbing a hill it would stumble. I would have to downshift going up hills to keep it from stumbling.
Any help would be greatly appreciated! It was in pieces for 3 months (blown head gasket) and it was finally back together and better than ever until yesterday.
Turn the key to accessory and then find the fuel pressure release vavle and use a small flat head and push the pin in...if if sprays alot of gas out then it is not your pump....it little comes out it is either the pump or a clogged fuel filter....also check each plug wire to make sure it is getting spark.
Dec 4, 2014 11:56 AM
lbrowne
Nov 13, 2011 04:25 PM
Anyone?
