CamaroZ28.Com Message Board
-   -   Car Is Acting Crazy!!! (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/car-acting-crazy-108606/)
97BLKZ28 Apr 17, 2003 03:45 PM
ok, i just installed cc-305,lifters, springs, retainers,locks, and a cloyes true roller timng chain. after the install i got the rockers tightened just right, everything back to normal.
anyway,at idle in park the car has a lot of cam surge, the oil pressure jump up and down from like 40 to 45, car has a kinda grinding whistling noise coming from up front. when i put it in drive it idles at between 600 and 700, and sometimes it dies when im sitting in drive but not going anywhere.
i am confused please help me.
is it possible i mixed a vacuum line up?
can an exhaust lead be part of it, because i have one?
thank you
97BLKZ28 Apr 17, 2003 04:42 PM
i just went to autozone and got the engine light scanned, found out it is the crankshaft position sensor, what the hell do i do now?
97BLKZ28 Apr 18, 2003 12:33 AM
just popped the car up and played with the sensor. got that fixed, anyway when i did my cam swap i didnt use my factory dowel pin on my new cam. is it possible that the new pin on the new cam is too long and is grinding into my opti?
i have a metal on metal , or a metal on plastic scraping noise coming from my car.
shoebox Apr 18, 2003 08:03 AM
It's a possibility.
