CamaroZ28.Com Message Board
-   -   Can't pull error codes from connection under dash!! (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/cant-pull-error-codes-connection-under-dash-126607/)
pillagenburn May 29, 2003 10:06 PM
Just as the subject says, I can't pull error codes. I went to Autozone, got them to plug in their OBD-2 scanner ... the thing wouldn't even turn on. Tried plugging into a different vehicle and it went right through. Is there a fuse that this connection runs through? I need to know what error codes i'm throwing or else I'm screwed. Thanks!!
shoebox May 29, 2003 10:25 PM
Check pin 16 of the DLC (bottom right, orange wire) for power. It is powered off the cigarette lighter fuse.
