Can't get the car to run afther otpi install.
Old Oct 6, 2006 | 06:09 PM
Camarorob1997's Avatar
Heres the basic recap from last Post http://web.camaross.com/forums/showthread.php?t=474618
It was timed like the book said camshaft at 6 oclock and crank at 12.
Opti, coil and basic few things plugged. VERY strong spark from coil, but very faint spark from wires to plugs.
The only thing it does is backfire a few times. I guess its not timed right, but wouldnt teh spark from teh wires be strong even if its out of time?
Also my grandpa made a new ping from a drill bit, its same lenth just a tiny bit fatter, its in there and must be in right whole if there is spark at all? It should be little bit shorter then .375 from cam gear to end of pin.
Help pls
Old Oct 6, 2006 | 09:15 PM
OBE1 95Z28's Avatar
Re: Can't get the car to run afther otpi install.
Mostly likely you don't have the opti on right; double check that the drive pin is in the right slot.
From Shoebox's site: http://shbox.com/1/opti_back.jpg
Old Oct 6, 2006 | 09:47 PM
UnitZ28's Avatar
samething happened to me... opti was on wrong
Old Oct 6, 2006 | 10:30 PM
Ok ill double check it tommorw if i can, Hopefully its in time. *crosses fingers*
cmdeshon
Dec 27, 2014 10:06 AM
startingstock
Exhaust System
Dec 12, 2014 06:40 PM
nophix
Nov 30, 2014 10:26 PM
USAirman93
Nov 24, 2014 03:37 PM
thenewkid
Nov 18, 2014 12:57 PM
