Pulled a fuse and now the engine is missing and acts like it’s out of time
I have a 94 trans am with a built lt1 and I pulled the #9fuse witch is Diagnostic Energy Reserve Module; Instrument Cluster; Remote Lock Control Module fuse and now the car is miss firing and Acts like it has a timing issue and if u drive it then it has nowere neat the power it did have does anyone have any suggestions on what I could have messed up ? Thanks in advance
Prominent Member
Location: Born on the Florida West Coast, now where can I retire?
Re: Pulled a fuse and now the engine is missing and acts like it’s out of time
Perhaps some add-on engine accessory has been tapped into that line. Does the engine clear up when you put the fuse back?
The instrument cluster connection from fuse #9 passes through (via a 470 ohm resistor) to the red wire on the alternator. Per the alternator wiring diagram that wire is "turn on input - (power up for regulator)”. Is it possible your system voltage is dropping to the point where the PCM, injectors, etc. are affected?
derrickgott007
11-17-2009 05:46 AM
wyldcdn
02-14-2008 05:06 PM
wiked95ta
08-09-2005 09:36 AM
stangitr
07-27-2004 12:44 AM
