can you shine up ceramic coated headers?
coated headers
had a tranny leak and covered header and caught fire header was black polished it with mothers looked brand new i think hooker uses either jet-hot or airborne but it did not effect the coating looked brand new it did soke a little when i started the car the same way they smoke when you install them from the oil on your hands dont worry it will stop will not affect the color
in my opinion extreme metal polish is wayyy better than mothers. I have both and to tell you the truth i never use the mothers anymore. I bought it at a tire place. I think discount tire sells it.
good luck
Brandon
good luck
Brandon
Originally posted by 95 Z/28 LT1
I would rather keep the dull finish and my ceramic coating than to scratch it off trying to shine it up again.
If you don't want to go off of my word, call HPC directly. HPC is the company that coats the AS&M headers. Ask them if it's Ok to use steel wool.
Steel wool is an abrasive. It may not take all the ceramic off of the headers, but it has to remove some of it, otherwise it wouldn't be doing anything.
If it is only cleaning contaminates/etc. off of the ceramic, then I can see what you are saying.
The ceramic coating is a LOT tougher than you may think. You could take a pad of 0000 steel wool and work it as hard as you could against ceramic coating for an hour and you still wouldn't see bare metal. If you're in doubt just call a few of the coating companies and ask them what they would suggest using for this situation. I wouldn't have offered the idea if there was a chance he'd destroy the coating.
