Can rear diff be rebuilt?
Old May 6, 2003 | 10:57 PM
DarkHorse's Avatar
I think I may be showing signs of "one wheel peel" and was wondering if I could have the rear diff serviced while having the gears installed or am I required to replace the entire diff. Any info would be greatly appreciated.
Old May 7, 2003 | 01:16 AM
Aeromaks's Avatar
my rear was whining, so yeah, rebuilt the rear, and threw in new gears while was at it.
Old May 7, 2003 | 02:53 AM
x7x7's Avatar
Your posi needs to be rebuilt. Rear-ends can definately be rebuilt but you need some special measuring tools and some knowledge.
Old May 7, 2003 | 06:45 AM
IDOXLR8's Avatar
I am pretty sure that stock differential are not rebuildable. Plus you can pick an SLP takeoff for $99.00. If you wanted a rebuildable posi I would highly recommend going with an Eaton posi.
Old May 7, 2003 | 07:37 AM
DarkHorse's Avatar
Got a link to the SLP take-offs or do I just call them? 100 bucks? Sweeet, should be able to replace that right along with the gears without any extra work correct?
Old May 7, 2003 | 09:16 AM
GREGG 97Z's Avatar
http://www.slponline.com/view_produc...TNUMBER=64501T
Old May 7, 2003 | 12:02 PM
LWillmann's Avatar
I haven't verified, but I heard that the SLPs were on backorder with no ETA...
Old May 7, 2003 | 12:29 PM
Zpower's Avatar
i currently have one tire fire too. i order the take off about a month ago, SLP said they are suppose to get them on May 6. so i hope they did, i should receive mine in a couple of weeks
Old May 7, 2003 | 12:57 PM
DarkHorse's Avatar
From what I'm hearing the stock unit cannot be rebuilt. This makes me miss my Mustang that much more. Easily have the clutch paks replaced.
How strong are the SLP units?
Is there a more complete way to troubleshoot the rear other than just looking for one wheel peel?
Old May 7, 2003 | 01:01 PM
Zpower's Avatar
i think the take off diff is hte same that come on the newer z28s/transams, if so, ive seen many do 1.5s-1.8 60's for a while now. either way, its better than paying 350? 450 for an eaton
Old May 7, 2003 | 01:19 PM
auto-Xer's Avatar
If SLP is on backorder, these guys have them: http://www.reiderracing.com/zexeltorsen.htm
Its the T2. They bought them up since the SS was scrapped. I think they were just over $100. I got the T2R though, makes a big difference in racing w/ turns
--Kevin
Old May 7, 2003 | 01:43 PM
x7x7's Avatar
I didn't know the posi units cannot be rebuilt. I assumed they could like the ford 8.8s.
But the rear can still be "rebuilt" meaning the bearings, seals, etc. can still be replaced. I had the bearings and seals replaced in mine last year.
Old May 7, 2003 | 02:40 PM
DarkHorse's Avatar
Ok, final question.
Is the differential a bolt in item or do I have to reset the gears as far as pinion depth, lash, etc......?
Old May 7, 2003 | 02:42 PM
LWillmann's Avatar
I'm not 100% on this, but I would assume that since the ring gear mounts the posi unit (diff) you'll have to reset the clearances on the gears after the swap.
Old May 7, 2003 | 07:21 PM
DarkHorse's Avatar
Thanks, if that's the case I need to contact a shop.
