Can I replace my ICM harness plug?
Old Jul 23, 2007 | 03:44 AM
96 WS6's Avatar
The white wire on my ICM harness was cut very close to the plug. I'd rather not crimp/solder or some other sort of half *** repair on such a crucial signal wire. Any way I can buy just the plug and some new terminals at the dealership? I don't know whether or not GM sells just that piece. Or can I remove the terminal and pull it out the back of the plug, fix it, then put it back in? It seems like GM connections are made so that the terminals can only be inserted, but not removed from the plugs.
Old Jul 23, 2007 | 07:04 AM
You can buy replacement pigtails. Here is a cheaper solution than GM.
Old Jul 23, 2007 | 12:51 PM
96 WS6's Avatar
Thanks Rob.
So what is the suggested way to insert the pigtal? Solder and shrinkwrap? Will that cut it for long term reliability?
Old Jul 24, 2007 | 07:25 AM
Originally Posted by 96 WS6
Thanks Rob.
Yes.
eazyZ
Mar 1, 2015 07:12 AM
Alex Barnes
Jan 24, 2015 10:21 PM
USAirman93
Nov 24, 2014 03:37 PM
JordonMusser
Sep 11, 2002 12:12 AM
