can i bleed my own lifters?
i am finishing up a topend freshening, and as i am installing new rockers, i noticed that my lifters are frozen. so i took the 2 from cylinder number 1 to my machinst, and he bled them for me. if anyone has dealt with a machine shop, then you know it could take awhile sometimes...
so as to speed up my project, i was wondering if i could bleed the remaining lifters at home? if so, a link to detailed instructions would be nice. i have been researching for a few days, but i havent been able to find anything.
thanks
jb
thanks
jb
Re: can i bleed my own lifters?
If you have a bench vise it is very easy...I never re-use lifters except for OHC applications, in which I use our arbor press.
Basically use something to press against the inside of the lifter while in the vise, tighten it down slowly and you should see the oil come out, back it off and repeat several times...you will feel when it bottoms out, dont try to go any farther. You will have to rig something up to keep the roller from driving you nuts, maybe a 20oz coke bottle cap will keep it from moving in the vise.
Originally Posted by OBE1 95Z28
How many miles on the lifters and are they still stock?
so, either they are stock with 46k miles, or are replacements with 4k miles on them. this is the first time i have been this deep into a motor with my own hands, so i am still learning as well. there are no id marks anywhere on the lifters, so i couldnt tell you if theyre new or not.
would it be better to buy new ones? looking recently, i could end up spending up to 500 beans for a set of 16.
thanks for the info machinist
jb
$216 for a set of Comp Cams R lifters from Thunder Racing
http://www.thunderracing.com/catalog...vid=4&pcid=107
Formula Steve
Sep 19, 2023 08:31 AM
