Can ANYONE tell me where to find replacment LT1 Rings
I need a good set of rings, BUT NOBODY SEEMS TO KNOW WHERE TO FIND ANY. Either that or nobody cares to share with me.
So PLEASE, tell me where to find a good set of rings, or just shoot me or something. -James |
Re: Can ANYONE tell me where to find replacment LT1 Rings
LT1 rings, i am assuming you are talking about piston rings, are not any different or anything special. Depending on what you are doing to the car, hasting moly rings would probably work just fine for your application.
Are you looking for rings for factory pistons? GM P/N 12528817 is the standard ring pack.
Also Speed Pro E-530K std for the original pistons :) You can get them pretty much anywhere. I got mine from SDPC2000.com.
[QUOTE= :) .[/QUOTE]
I have some NEW (still in the box ,NEVER used) Hastings rings for a stock lt1 piston. They are 60$ plus shipping from the Houston area . If you want them post, because I don't know if my old aol email is still active. (Just got road runner a few months ago, and still have not set up a new email.) Anyways my old address is Class499@aol.com if it is still active. Try posting here first though, and I can give you contact info if it does not work... if you want them. I have stock USED lt1 pistons in good condition (cylinders still had the cross hatch pattern), with wrist pins also. Again the rings are NEW, and still in box, but the pistons are USED. |
