Camshaft swap parts list
Final parts list check. Let me know if I missed anything.
EX-612-16 612 Single Coil Extreme Performance Valve Spring Kit, includes lightweight retainers and locks CC-1302-16 1.6 Pro Mag Rocker Arms - 7/16 studs - Hardened Pushrods - Comp R Lifters - CM Double Roller Timing Chain - CSI Water pump Gasket Package - CC 233/239 .569/.577 112ls cam - Cutout - 95' Front Cover Vented Opti 1104032 - Vented Opti elec harness 12130319 - Vented Opti vented vacuum harness 12555323 - 1LE Elbow for vented opti 25147187 - GM Guideplates - Where can I get the CSI elec. water pump, and where can I get the GM parts I need without being ripped for shipping through gmpartsdirect? Thanks Edit: This will be on a 94. What's different about the opti's electrical harness anyway? |
I would think you would know that Dal or Jason are the people to get your GM parts from.
Dal Slabaugh: 877-448-5451 email: lockitup@bright.net VanDevere Buick/Pontiac/Olds Akron, OH or Jason Cromer: 877-726-8295 or 850-243-8826 (direct parts dept ph #) email: gmparts@samtaylor.com Sam Taylor Buick/Cadillac Ft. Walton Beach, FL Since you are getting some parts from Combination Motorsports, they can supply you with a lot of things (gaskets and such). The connector on the opti end of the harness is longer on the vented opti. The pre 95 harness connector will not reach far enough. You might also look at my cam install page. There is a list of items at the beginning that might be of some help. The p/n for the GM guideplates is on my valve spring swap page. |
I've got the guideplates already. Thanks for that info though, looks like I'll be going through Jason to get the stuffs. Gaskets are taken care of --- EXCEPT
What do I need to plug the water pump hole? And where can I find the CSI pump? |
Originally posted by Spinner I've got the guideplates already. Thanks for that info though, looks like I'll be going through Jason to get the stuffs. Gaskets are taken care of --- EXCEPT What do I need to plug the water pump hole? And where can I find the CSI pump? |
Any parts I'm missing, or does that look complete?
I think the plug comes w/the water pump if Im not mistaken. it is a freeze/expansion plug.
