cam question on smogability
does anyone have experience with putting a 218/224 on a 112 base circle through smog? it is a comp cams grind if that means anything for overlap.
Re: cam question on smogability
It will pass with everything else working properly. The hotcam passes, and
I have even heard of the GM 846 and CC 503 passing smog. I have no direct experience, this is just what I have read from the board. Check out this link on the Impala SS board: http://impalassforum.com/noncgi/ulti...c;f=1;t=000062 |
| All times are GMT -5. The time now is 08:00 AM. |
