Cam & Lifters
Old Oct 2, 2020 | 09:26 AM
weedog's Avatar
Cam & Lifters
What would be a good Cam & Lifters to put in my 97 Z28 that i will use for the weekend the most. Will drive a little during the week. I turn 63 in May so in a few years my Grandson will get it. The engine will be stock all but the Cam & Lifters and going to put Headers back on it. Thanks
Old Oct 5, 2020 | 08:44 AM
Chimera96's Avatar
Re: Cam & Lifters
Most agree a custom grind cam is better and the cost is minimally more. Contact Lloyd Elliott at Elliott Portworks or go to his site and look at available options
Whatever cam you get you will need the PCM tuned for it. If you stay on the mild side your stock injectors should be fine
Old Oct 10, 2020 | 07:52 PM
weedog's Avatar
Re: Cam & Lifters
i was told by Lloyd Elliott that he can not get any cams right now because of the virus.
Old Oct 10, 2020 | 10:25 PM
1994-LT1-Eric's Avatar
Re: Cam & Lifters
That sucks ☹
Old Oct 11, 2020 | 02:19 PM
Chimera96's Avatar
Re: Cam & Lifters
weird...the automotive parts and rebuild business is exploding as a result of COVID
Off the shelf cams are OK. For the Ops needs a Com 502 since his heads will remain stock
https://www.summitracing.com/parts/cca-07-502-8
any cam will need new valve springs
https://www.summitracing.com/parts/crn-10309-1
these are better springs
https://www.summitracing.com/parts/lun-73925k5
Lifters. Comp 850's or these
https://www.summitracing.com/parts/lun-72910-16
Old Oct 19, 2020 | 10:23 AM
kramer427's Avatar
Re: Cam & Lifters
I just ordered a custom cam from Lloyd Elliott last week.He said about 2 weeks to me.
colossus
Sep 18, 2005 08:58 PM
Damon
Advanced Tech
17
May 15, 2004 09:11 AM
NightTrain66
Apr 19, 2004 08:52 PM
PooHoopy
Mar 24, 2004 11:52 AM
93_Z28_6spd
May 27, 2003 10:03 PM
