cam install done;ran fine for a day, now wont start
finally got my 306 cam, headers, cloyes double roller, electric w/p installed sunday. Car started right up, no leaks or probs at all. Drove it all day sunday, no probs., car really pulls like a **** now!! Drove it to work this morning, letting some buds hear the cam, I reved it to bout 5k or so and it idled down then died. Tried to restart it and random firing, then a LOUD a$$ bang out of exhaust pipe (actually blew off the thunderacing s-pipe, planning on welding it tomm.). I smell gas bad, pulled plugs out(new ones) dried em with a heat gun, still nothing, very random fire, then another boom out the exhaust. Had a freind pull me and tried to start it that way and nothing. I did notice coolant coming from somewhere. not sure where yet. How can I check the opti to see if its bad or not?? I dont want to pull the front half of this motor off again My opti has been wet a few times with no trouble at all. And yes, the coolant was around the opti, but nothing major. I'm fixing to check to see if the plugs are getting fire now, just got it towed home and on stands now, wanted to get this ? on here quick as possible. By the way, this thing sounds like a freakin 9sec. ride, real, real, nice lope This is really pissing me off, it was running perfect this morning, start right up, idle bout 1100, just a little cam surge if ya dont rev some befor u take off but other than that this thing is the ****. I want to specialy thank shoebox for all the help and anyone else who helped me. If it wasnt for this board I prob. would have never modded this thing at all. Hummm. maybe I shouldnt have became a member, I'd have bout 10k still in my pocket, oh well, u cant take it with ya. HELP!!!!!!!!!!!!!!!!
pcmforless programming. Like I said car started on the first crank, ran perfect for exactly 55 miles. No ses lights before it happened, it just wont fire. Can u scan the car with it not running? You might get 2 or three "fires" out of it while cranking but thats is it, it backfired 3 times out the exhaust VERY loudly on a few of the cranks??? If its not getting fire how can it pop out the exhaust?? and pissed!!! Had a good race tonight with a novi-charged stang too, this is gonna make me look like I'm backing out now!!
alright, pulled no. 1 plug, grounded it with wire on to the ground lug on coil, cranked motor, no spark. Where to start now? Getting fuel for sure. Yea, yea, I know I shouldnt have revved it that high with no load on it, ya know how ya get with a new toy and friends around But i cant see it jumping a tooth with a 5k rev???? Not saying its not possible though.
the dowel pin is the same length as the factory one,had to cut it to fit but I'm sure its the same length. Shoebox, I checked out your link a while ago and I'll give it a try tomm. Going to bed now, sick of screwing with this car for the moment, I want to drive it!!
shoeboxI followed your test on your tech page about testing the icm connector. The A term. had 2.12 and the D term. had 1.87. Thats way off from what your readings say they should be. Does this mean opti or module?? I'm assuming opti from what I got out of your page but just wanted more opinons on this before I order parts. Car has 80k on it, factory opti. 4 w/p's have on it and a couple of car wash sprays, think i should just replace it any way?? thanks again, Chris
thanks shoe, I'll give that a try. Yes i did check the ign. fuse and it looked good. I just thought of something, I ran my wire for the CSI pump to the ign. fuse. I used an install guide, Ken Lowerance web site, for the wiring. I used a relay and ran the wire from the 86 terminal on the relay to the ign. fuse. I just pulled the fuse and stuck the wire under the blade of the fuse and popped it back in. I know its ghetto but is it possible that had something to do with it? Like I said the car fired right up, ran PERFECT for exactly 55 miles, pump works fine, it still working now. Do you think that could have anything to do with it? Thanks again Shoe, u are the man!!
F(ast)-body
02-26-2003 09:05 AM
supercharged94Z28
02-24-2003 10:22 PM
