Cadillac Fleetwood LT1 - will I have a swap problem into my Z28???
I have a 94 Z28 M6 and I bought a 94 LT1 out of a cadillac fleetwood to rebuild and swap in. Now I know the LT1 was used in the fleetwoods, caprices, impalas, camaros, etc.. but are there any reasons between them that should cause me any trouble swapping the engines? I haven't seen it yet and it was brought to my attention that it might be longer?? for some reason to supplement the tranny on the longer fleetwoods and caprices. does anyone know a little something about this, I dont.....
Re: Cadillac Fleetwood LT1 - will I have a swap problem into my Z28???
they are identical except for the heads and cam. I've done this swap for a couple of customers wanting to save a buck. You'll like the lowend grunt but you'll notice a difference on the top end.
Shawn
Shawn
The one that is in my car now was out of an Impala SS and on thursday I bought another on out of a caprice for my next project. Those Lt1's have cast iron heads as opposed to the aluminum ones on the fbody and vettes, as well as a slight different cam grind to provide more tourque fot the added weight of the bigger cars.
It has a vented opti which is good. It has 2 knock sensors, removed the one on the driver side and plug it. And the exhaust manifolds are different, reuse the ones from the f-body.
Originally Posted by Evil Eric
might be a good idea to do a port job on those iron heads just to open them up a bit before you stuff it in the car.
Sorry the iron is bad ignorance just hits a nerve with me.
LOL I always heard good things about these heads from my buddies; but everyone on here has told me to invest in an aftermarket set too or to get them ported, but I'm a newb, what do I know
If you want more than a stock motor sure port them or your old aluminums or if you want a wild motor look to aftermarket heads and porting, but stock for stock the irons outflow the majority of the aluminums so the iron hatred often seen on forums is just from a lack of information. If you want to go ported the aluminums already have screwin studs which is a plus for use with big cams, the irons are pressed in and they should be machined to screwin if you plan on anything with say more lift than the HOT cam with 1.6 rockers. The aluminums obviously weight less but sources I trust have weighted each and put the difference at more like 35# for the pair rather than the 50# often quoted. The aluminums have a smaller chamber for more compression but iron is more thermally efficent, each has plus sides and drawbacks and both are pretty good in stock form. As I said though I get tired of the anti-iron sentiment from many f-body kids.
Shawn
Shawn
LT1s that came in the Fleetwoods were (in most cases) the smaller baby LT1 (265ci) rated at 200HP.
...could be wrong I suppose.
but unless you pulled it from the Fleetwood, make sure its a 5.7L
To get a solid 400hp out of an LT1 your best bet will be heads and cam, how wild on the cam will depend on how much you sink into the heads, you can do it with just a cam but you may not want to go big enough to get there.
A buddy of mine used the LT1 out of a caddy to build his 355. The intake, heads, cam are all different. What you should do is pull the heads off your old motor and either have them ported or at the very least pull the damn cast iron heads off in place of the aluminum. And youll really wanna get a cam if its all appart already because IMO its really a waste to do the cam swap later when everything is so easy to get to now... it would be real mistake not to.
Unless you add a larger cam and heads then stick with your stock injectors. Larger injectors dont mean more power unless the motor requires more fuel than the stockers can supply and that will take a heads/cam motor to do.
[QUOTE=...but iron is more thermally efficent..[/QUOTE]
What do you mean? Aluminum conducts heat approximately 4 times better than iron.
