A.c.&p/s Delete???
I'M LOOKING TO INSTALL MY LT1 MOTOR IN MY 69 CAMARO BUT I WAS WONDERING IF SOMEONE MAKES AN AC DELETE PULLEY AND POSSIBLY A POWER STEERING DELETE PULLEY.
If you are deleting the AC and PS, there is nothing left for the belt to drive except the alternator. Instead of getting "delete" pullies, simply get (or make) the bracket to drop your alternator down below the engine, and use a simple belt (no tensioner) from the crank pulley to the alternator.
they do make an AC delete pulley, I just put one on my car. AS far as PS delete, I haven't seen a ready made pulley, but you could have one made pretty easy. Or you could low mount the laternato where the AC used to be and possibly kill multiple birds with one stone... There are pics of this setup floating around here somewhere
But would relocating the alt. to the bottom work if I wanted to put a supercharger on the motor too?
here's what you need: http://www.madmanandcoracing.com/lt1...orbracket.html
You will still be able to mount a SC, since it sits on the other side and uses different pulleys. |
Steve10 also has what you need: http://www.mycamaroz28.homestead.com/
THANKS.:bow:
power steering delete pulley
just saw a powersteering delete pulley on ebay
| All times are GMT -5. The time now is 08:22 AM. |
