Build tips on a driveable S/C 383 or a N/A 396
Old Jan 31, 2006 | 06:50 PM
jetman's Avatar
Cool Build tips on a driveable S/C 383 or a N/A 396
I want to build a driveable S/C 383 or N/A 396, and what HP/TQ would I be able to make with a driveable set up.
Old Jan 31, 2006 | 07:14 PM
MEAN LT1's Avatar
Re: Build tips on a driveable S/C 383 or a N/A 396
Your question is VERY broad.
Old Jan 31, 2006 | 07:59 PM
LameRandomName's Avatar
OK, broad answer to go wqith your question.
On NA use 9.5-10 compression and a cam with a 1500-6000-ish rpm range.
On a SC engine, use 8.5-9.0 compression and 7-8lbs of boost on the same cam.
Old Feb 1, 2006 | 06:44 PM
jetman's Avatar
I should of said what would be a good set up for a driveable NA 396 or a SC 383. Can 500RWHP be obtained and still be driveable. Is a SC worth the hassle. How much boost can you get away with I was thinking about a 6psi procharger and keep the compression at 10:5:1 as long as the bottom end was built for it and I had all of the supporting components, heads,cam, exhaust, tune, ignition, and fuel system.
As far as the N/A 396 goes how radical could I go and still keep it driveable. How much compression, I was thinking 11:5:1 a good set of heads and a cam with duration around 230's intake and 240's exhaust and lift around 550 to 600 and have all of the supporting components as mentioned above.
I have a extra LT1 on a engine stand that needs a home so why not build a killer set up for the street/strip.
Old Feb 1, 2006 | 11:04 PM
SStrokerAce's Avatar
Real question is do ya have the budget for it...
I don't care if it's a motor build or your building a new computer (as I am now) whatever you do take your planned "budget" mulitply by 1.5 (50% more) and find out how to get that much money so you can complete it.
Bret
Old Feb 1, 2006 | 11:20 PM
RedLT4Mike's Avatar
^ that is a major consideration indeed!
Everyone should consider that FIRST, so we
can see some cars reach completion around here.
I've seen too many projects being aborted that are
near completion lately. There's nothing that is more
of a buzzkill than not finishing what you start.
Old Feb 2, 2006 | 07:04 AM
BlackScreaminMachine's Avatar
My motor is waaaaaay over the 10k mark.......
Old Feb 2, 2006 | 07:05 PM
jetman's Avatar
If I start this project it will be finished. Not only the engine but I'm talking a whole new drive train as well. No sense in building a killer engine and not have the rest of the required components. I've been doing some research and I can get the short block built for about 3k and thats a 396. I thought I would go with one of Combination Motorsports cylinder head and cam package's either stage 2 or 3.
I think 500RWHP N/A is possible, in the November 04 issue of GMHTP there is a 94 Z28 making 550 Flywheel HP with a N/A 396. His heads are home ported with 2.00/1.60 valves. His intake is also home ported. His compression is 12.0:1, I would lower that a bit like 11.5:1. His exhaust is LT with a Y-pipe and a Borla cat-back.
Old Feb 2, 2006 | 09:57 PM
Good luck with that Jetman.... nobody around here has done a 500rwhp motor for that little.
Old Feb 3, 2006 | 10:29 AM
97WS6SCharged's Avatar
Doubt it would be much fun to drive on the street either.
Old Feb 4, 2006 | 08:36 PM
jetman's Avatar
Is 500RWHP and still be streetable asking for to much.
Old Feb 4, 2006 | 10:08 PM
On your budget, oh yeah
Old Feb 4, 2006 | 10:43 PM
amean94ta's Avatar
almost times two and still climbing every year lol
Jun 6, 2015 08:27 AM
cheapchevy
Apr 8, 2015 08:48 PM
transam_388
Mar 15, 2015 11:53 AM
pimpss96
Feb 12, 2015 01:28 PM
