CamaroZ28.Com Message Board
-   -   Budget Racer (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/budget-racer-200115/)
Heatmaker Dec 5, 2003 02:50 AM
Budget Racer
I'm looking for a Kick ASS cam!
I figure doesn't make since to go through all that for the waterpump and not do something with the cam since I'm right there.
What cam should one look into for making agressive Street power...but still good enough for every day driving?
Already Set on a set of 1.7's.
The only thing is that I don't plan on getting the Stock Heads worked till August sometime.
If I get an agressive ass cam will it hurt my engine? If I don't have the easy breather heads?
Also....If I do the cam and lifters now...but the cam requires PCM tunning....will I jack my car up if I don't get it tuned anytime soon?
Like not for a couple of months?
"B-Easie Dawg B-Easie"
S.J.S. Dec 5, 2003 02:57 AM
For everyday driving...I'd go with the Hotcam or the C305. You don't want surging and idling probs.
If you decide to go aggressive......no a poor flowing head won't hurt it but you will not get everything you can outta the cam without some good heads. The stock ones will choke um.
You'll need to ge the tune. Depending on what size cam you're going with......it might run like crap.
RedPhenx Dec 5, 2003 02:59 AM
you can run decent with a 306 on stock heads, but it also depends on what kind of exhaust work you have done
plus, do you have an auto or manual?
Heatmaker Dec 5, 2003 03:08 AM
I have a manual T-56
With full 3 inch exhaust...hi flow cat...Circle track muffler...shorties blah blah....you get the idea
So in other words It's better to wait and just do my cam job after I get the heads worked?
97WS6SCharged Dec 5, 2003 04:54 AM
Go ahead and do the cam, but instead of the 1.7 rockers, get something that gives better valve train geometry like a 1.5 or 1.6 and get the lift from your cam instead.
AxeGrinder30thZ Dec 5, 2003 08:12 AM
I would just save up more money to get the cam and head work done at the same time. A cam will really respond to a set of racing heads or ported/polished stock ones.
Heatmaker Dec 5, 2003 04:37 PM
:p
FastZinTennessee Dec 5, 2003 05:20 PM
If you're looking for a kick ass cam get the CC306 and a tune. You need headers though, and I'm not sure if you said you had them or not. I don't think it would hurt anything, but I would not do a cam before some headers.
Sweetred95ta Dec 5, 2003 07:10 PM
Mwa ha ha ha ha, GM847 all the way. :metal:
Benji
b-stevens Dec 5, 2003 07:18 PM
I dont think many people would recommend 1.7rr's with a mean ass cam
Heatmaker Dec 5, 2003 08:53 PM
I always thought the Larger rockers were at an advantage.
b-stevens Dec 6, 2003 09:59 AM
With stock cam 1.7s might be ideal for the best gains, but with a cam like the gm847 or the xe230/236 or any of those, the lift numbers might be a little too high for stock heads, and even with good flowing heads alot of people wouldnt use 1.7s, would somebody else like to chime in at this point?
b-stevens Dec 6, 2003 10:09 AM
for instance, on a stock 94-95 cam, the duration is 203/208 and the lift numbers with 1.5rr's are .450/.460, 1.6rr's = .480/.491, 1.7rr's = .510/521....
on a 230/236 the lift numbers would be:
1.5 = .510/.521
1.6 = .544/.556
1.7 = .578/.590 or .591 if you are supposed to round
Heatmaker Dec 6, 2003 12:24 PM
Yeah your right
I'm glad I found this board...saving me allot of money and frustraition.:D
Compstall Dec 6, 2003 01:08 PM
"uhhhhhhhhh hu-hu-hu-hu-hu, they said Ass Cam"
