brake problem..help!
Old Mar 22, 2003 | 12:26 PM
xxsaint69x's Avatar
alright guys....i need STEP by STEP instructions how to bleed the whole system..i just spent 2 hours bleeding it and my brakes stil suck....the pedal is mushy up top and gets Rock hard not even half way down, and the car bearly stops..i cant even trip the ABS
goin 65 mph and slaming on the brakes!!!
Thanks!
ps..i want to change ALL THE FLUID too..how do i go about doing that? I think i got most of it out, but it still kinda dark.
Old Mar 22, 2003 | 01:08 PM
ZDriver96's Avatar
Do a search on my user name in the lt1 and ls1 search. I posted a few times about this. Im still having a problem with mine. I believe i have to bench bleed it since i ran the master dry.
But basically start with the Right rear, then left rear, then right front, the left front.
You could probably bleed the 2 ABS bleedings on the ABS modulator too.. (The silver box under the hood with your brake lines going into it). Make sure you keep the master cylinder topped off of fluid and dont let it get too low while bleeding. If someone's pushing on the pedal while you bleed make sure your open the bleeder valve after they put there foot down and you close the bleed valve before they release their foot from the pedal. Im using a vacuum to suck all the air out.
I ended up doing it in this order but after a while of bleeding i just started bleeding the **** out of everything everywhere.
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
cohopefull
Sep 8, 2015 03:22 PM
maverickmk
Sep 1, 2015 09:17 PM
