Brake light stays lit on dash...
I just bought my 1994 TA and for some reason the brake light stays lit up after the car starts up. Some times the light will flash and if I stay at a very constant speed, the light WILL go away. Do you guys have any ideas? I was thinking possibly a faulty sensor. If so, where is the Brake sensor
And the parking brake works fine and you can set the e-brake. |
Either you are low on brake fluid, if not just undo the cap and retighten it; or your 3rd brake light burt out, or you really have a problem with your brakes.
Travis |
