Brake booster
Old Mar 14, 2005 | 07:56 AM
IXLR894Z28's Avatar
Brake booster
Mechanics say that I have a vacuum leak at my brake booster, is this part hard to change?
Old Mar 14, 2005 | 08:01 AM
IrocSS85's Avatar
Re: Brake booster
not really hard. two nuts on the outside and you can pull the brake master cyl. forward (no need to disconnect any brake lines). then on the inse, there are 4 nuts directly behind the brake pedal. then you have to disconnect the brake pedal pushrod from the brake pedal linkage. if you got some free time, anyone can get it done.
chris
Old Mar 14, 2005 | 08:07 AM
Re: Brake booster
It's that big round thing between the master cylinder and the firewall. It unbolts from inside the car, under the dash. Just awkard to get to.
Old Mar 14, 2005 | 09:11 AM
IXLR894Z28's Avatar
Re: Brake booster
Thanks, I'll start calling stores to see how much this will set me back.
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
maverickmk
Sep 1, 2015 09:17 PM
whitehooptie
Jul 12, 2015 06:10 PM
