Bolt on LT1 at the dyno
Went to the dyno today. Can't say im upset or happy. Didn't really know what to expect. . Put down 289whp/323tq. Air fuel was pretty close to dead on. Besides the second pull it was a little leaner. Is that normal for my mods? Was done on a dyno Dynamics dyno. Temp was around 85. Pretty much stock with hollowed cats i put down 262whp/ 285tq. Ill get the sheets up tomorrow.
Mods in sig. Only difference is 3.42's and have umi lower control arms and panhard bar. I also have a set of 1.6rr's and crank pulley going in next week to help boost some power |
1 Attachment(s)
Dyno sheet-Attachment 31211
For the mods listed I think those are good numbers, remember HP does not move the car TQ does!
they dont look bad. Do you have the pcm tune yet?
The crank pulley isnt worth too much but the rockers should be 10-12rwhp all in the upper rpms. Your going to want to spin the motor a little higher with them too. |
You got exactly what is expected of those mods. It's not a weak lt1 to begin with so be happy.
Hal |
headers and cai. numbers look fine. rockers might put you at 300. i was at 326 with longtubes, factory lt1 ws6 ram air setup and a 224/224 cam with supporting valvetrain, so yours looks good to me. my tq was at 345 tho:)
Originally Posted by slomarao
(Post 6040437)
Originally Posted by Hal Fisher
(Post 6040475)
I'm extremely happy. Really didnt know what to expect Hal
Originally Posted by 69z-28
(Post 6040524)
I ran stock springs with my stock cam and 1.6 RRs Comp Cams Pro Magnums, no problem. When I upgraded my cam, then I upgraded my springs.
Originally Posted by 95ltslow
(Post 6040539)
Yes, I have a mail order. And the a/f is pretty much dead on.
I'm extremely happy. Really didnt know what to expect I plan on h/c in the near future. I'm being told that the stock springs wont work with 1.6sa rr's.? is this true |
I like the TQ curve.......Solid flat across the board......That's a street car that drive with the best of them.
Geez! look at that torque curve... well, line.
what about a ls lid, ssra or ftra and the rockers springs. Than a cutout.
You should be close to my numbers. its a strong car. |
Originally Posted by Kevin Blown 95 TA
(Post 6040705)
One problem with your stock springs is that they are 15 years old and probably all worn out. You should probably change the springs when doing the RRs.
Originally Posted by crash4cyl
(Post 6040708)
Originally Posted by MikeGyver
(Post 6040832)
(Post 6041137)
I'm heading back to the dyno after the rr install and a tune. I have dual cutouts on my y pipe. Would I see any power increase by opening up both of them?
