Blinker bulb problem!?
Old Mar 25, 2003 | 09:34 PM
ibanezgod's Avatar
Hey my blinker went ka-put and my mechanic says cuz the socket in one of my rear lights burnt out or is just toasted. So I guess i have to replace the socket along with a new bulb. Does this sound normal? If so ... anyone know what parts i would need exactly to fix this myself? Difficult at all?
Old Mar 25, 2003 | 10:29 PM
sp528's Avatar
Before you replace the socket check the black ground wire on the non-working socket. Wiggle the wire around, and the blinker might work again. But if you dont want to mess with it just get a new socket from a dealer or good parts place, or you could also go to a junkyard and get one for like $1.
Old Mar 26, 2003 | 04:04 AM
ibanezgod's Avatar
thanks, hopefully its a cheap fix w/e the problem is...
Old Mar 26, 2003 | 05:35 AM
BigEvil's Avatar
It's pretty common from what I hear. I've had to replace 3 of mine over the past year. Well, maybe not had to, but did it when problems occured just to keep from a recurring problem. Like sp528 said, you can get them really cheap from most junkyards.
mattstrike
Mar 24, 2015 02:11 PM
silvermansteve
Mar 4, 2015 05:02 PM
squarehead
Jan 15, 2015 07:02 PM
