Bigger Injectors?
Bigger Injectors?
At how much power does someone usually need bigger injectors? I plan on doing an XE 227/233 cam and long tube headers... I was told 360rwhp is about where it will be. Would I need bigger injectors then? If not injectors... what other things do I need to compensate for the power? Other then a 12 Bolt or 9".
Re: Bigger Injectors?
You doing heads too? 360rwhp seems a bit high I think if your not assuming you just have the "bolt ons". I would think you would be in the 345 area. Let us know, dont see to many dyno graphs with that cam yet.
Originally Posted by ChrisUlrich
Dave from CombinationSports said 380 was done with those mods... 360 is more then likely...
Dave's gonna have alot of explaining to do when you only dyno 345 then
