Bigger cam+catalytic converter=more smoke from exhaust until warmed up?
Old Mar 15, 2004 | 06:48 PM
FastZinTennessee's Avatar
My car has been smoking more than normal lately, but if it does it it's only when I first start it up in the morning, smokes for about ten minutes then stops. It's like the car is running rich while warming up, smoking, then when it quits running rich the smoke stops. Anyone else had this happen?
It's a HOTcam, ported heads, random tech high flow cat, PCMforless tune.......
Old Mar 15, 2004 | 07:32 PM
Don't Look Back's Avatar
I know mine smokes like a bastard on cold mornings. No cam, but I have a gutted cat. Makes sense that a high flow cat and a bigger cam would act the same. I think the smoke is a result of the AIR pump until it shuts off.
Old Mar 15, 2004 | 08:20 PM
I've removed my air pump. This really freaked me out because I thought all the smoke was a blown headgasket, but the guys I know at the mechanic shop ran a few tests and said for sure that I don't. The smoke gets pretty bad sometimes.
If more smoke than usual is normal I'll live with it, just kind of unnerving to look in the rearview and see a plume of smoke at stoplights
Old Mar 15, 2004 | 08:47 PM
Even without the AIR pump, i'd think its normal. Mine smokes out the street some mornings.
Old Mar 15, 2004 | 08:52 PM
Ok great, that makes me feel better
Anyone else?
Old Mar 15, 2004 | 11:24 PM
Terran2k's Avatar
mine is basically stock, and on cold days when i start her up for the 1st time that day, she'll smoke it up till the moisture evaporates that had condensed in the exhaust.
Old Mar 16, 2004 | 12:22 AM
Indy93Z28's Avatar
Mine has a lot more smoke when cold than before. Big ol white cloud forms at the beginning. It wasn't as much before cam. I did notice that my car stopped producing smoke faster than my friends none cammed cars tho while getting warm..
Old Mar 16, 2004 | 12:54 AM
6Speed's Avatar
How many miles are on it? It could be the rings. When it warms up they expand enough to seal up, but when it's cold it might burn a little oil.
Old Mar 16, 2004 | 10:10 AM
It's definitely white smoke...... 138k miles.
The guy I know that works at the mechanics shop said that if a car is loading up on fuel then it can produce more white smoke that usual out of the exhaust. He said that he had a car come in with an injector stuck open and it was pouring white smoke out.
I think maybe the tune on the car is programmed to dump a lot of fuel in while the car is warming up to "light off" the catalytic converter. This might be even more so since I have a PCMforless tune, as I'm not sure if it's running richer at idle now.
Old Mar 16, 2004 | 10:22 AM
2MCHPSI's Avatar
white smoke sounds like oil, not runnng rich.. Most likely your predefined cold start fuel trim values are on the rich side. When it hits closed loop, it takes over and is ok.
Old Mar 16, 2004 | 04:36 PM
I thought oil was blue or darker colored smoke......
Old Mar 16, 2004 | 04:38 PM
Yeah, it is. I know mine smokes white, and when you stand behind it, you can smell fuel. If it were bluish and smelt like burning oil, than that would be the problem.
2MCHPSI's Avatar
blue and dark smoke is most likely running rich.
Old Mar 16, 2004 | 04:55 PM
This might be a good excuse to buy a wideband and get a dyno tune
QuickSilver02
Apr 7, 2015 11:12 AM
captcorvette
Mar 7, 2015 12:37 PM
MattFick
Feb 15, 2015 10:16 PM
dale3in98
Feb 14, 2015 12:18 PM
