Big problems engine may be really screwed help!
Old Sep 22, 2004 | 05:36 PM
Bad64chevelle's Avatar
OK....today i went home for a few...and the last time i drove it the car pinged popped rattled and backfires....so i figured id change the coil wire while i had a few free mins cause i knew that was a problem. I changed it, put some new gas in it along with injector cleaner and boom the same thing happened....so i figured maybe i should get under the hood again for a better inspection. I sat there and revved it up..and listened to this thumping noise coming from the engine...i cannot explain it it almost sounds like something is loose and maybe its pinging but its a really weird noise....I really am stuck now cause this IS my set of wheels and i cannot drive the chevelle daily when it gets less than 10MPG...HELP!!!
Oh yeah the noise seems to be coming from the front of the block almost like the number 1 and 2 cylinders...
Its a 94 Z28 A4 with 60k on the clock..thanks
Old Sep 22, 2004 | 08:18 PM
92rslt1's Avatar
Re: Big problems engine may be really screwed help!
does it knock at idle .. you probably are about to pitch a rod.. hows your oil pressure??
Old Sep 22, 2004 | 09:22 PM
no it does not knock at idle...only when its revved up...my oil pressure gauge is broken...how do i put a mechanical one on the vehicle...any more ideas?
Old Sep 22, 2004 | 10:36 PM
92rslt1's Avatar
could be a main as well. rod slap s constant while most the time a main will knock at higher rpms when the crank gets whizzing around. did you lose alot of power? what type of codes does this throw??
Old Sep 22, 2004 | 10:39 PM
92rslt1's Avatar
a mechanicl oil gauge.. roughly.. unscrew the oil level sender. screw in the mechanincal oil fitting. run the clear oil hose to the oil gauge.
Old Sep 22, 2004 | 11:30 PM
HAHA ok...i heard i could also run a line from above the oilfilter and go to the gauge...i heard if i disconnect the original gauge ill shoot an SES light...is that true?
I havent gotten an SES light yet??? i dont know what to think!
MadMav
Feb 6, 2015 11:02 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
HCz28
Jan 11, 2015 11:21 AM
mspennyhughes
Nov 28, 2014 03:22 PM
squarehead
Nov 21, 2014 08:02 PM
