best vent location for scanmaster
I want to put my scanmaster in my vents on my 94. I'm thinking of putting it in the vent by the window, but i still want my a/c to blow me effectively.
So, i'm wondering which vent would be the most crucial to keeping me cool?? probably the center vent over the radio???
Re: best vent location for scanmaster
If it were me, i'd put it to the left of the steering wheel. Theres 2 vents on that side: a lilttle one and a big one below it some. Put it in the little one, and you will still have that big one to blow you.
I tried putting mine in the left vent. It was a disappointing experiment. There is a separate, hard nozzle that feeds a little grill for defrosting the section of the window for the rear view mirror. This hard nozzle, as it sits will not allow the scanmaster to reside in that vent unless you remove the nozzle and lose function and benefit of it. I wish I would have taken a picture of the layout but if you remove the instrument bezel you will see what I am refering to immediately.
I ended up repairing that adjustable left vent nozzle and proceeded to put it where Brent has his installed.
Originally Posted by OBE1 95Z28
I have mine located in the left vent and it ties in well with my dual gauge pod that's mounted on the A pillar. No issues with defroster on drivers side. I also had very little air flowing out of the upper vent previously to the install.
I removed my ScanMaster from its plastic housing to mount it in my vent. From the outside, it looks just like the photo on Brent's website, except it's mounted in the left eyebrow.
That explains why you had the room to mount it there. I only needed another inch in the front to back spacing. I'm going to guess the PCB with its components is really just a few inches square with only a couple of chips and resistors. As small as the Scanmaster is, it could be made even smaller. I'm not going to open the case on mine but I sure would have liked to have put it where you have yours. Thanks for the explanation.
whitehooptie
Jul 12, 2015 06:10 PM
