Best ignition box
Old Aug 19, 2007 | 12:34 AM
horse-power400's Avatar
Best ignition box
I'm trying to decide which box to buy for my 95 camaro. I've been looking at the MSD 6AL, Mallory 6AL, Accell 300+, Crane Cams HI-6R or S. I have heard a lot of good things about the MSD but wondered if any of the ones I listed was better? Is there a big difference between analog and digital?
Old Aug 19, 2007 | 12:53 AM
Z28LT1_Just_Nasty's Avatar
I've always heard very good things about the MSD Unit. When the time comes for my setup to need it down the line, thats probably the one I'm going with.
Old Aug 19, 2007 | 06:38 AM
solarofthesix
Guest
Posts: n/a
I went with the 6AL and everyone I have talked to that has one loves their 6AL. One thing to be sure of when you put this in is swap out your plug wires for NON SOLID CORE. The MSD will blow stock replacement wires form the inside out. It did this with mine, and then i rememebered reading abotu that in the literature that came with the box. Also i dont know about the other boxes but MSD also gives you a Rev Limiter that you can custom set independently of the stocker AND if you have an aftermarket tach you can plug it into the MSD Box and get a more accurate reading. My 3rd gen was abotu 300rpm different between teh cluster tach and the Autometer that I had pluged into the MSD.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
detroit1994z28
May 14, 2015 12:09 AM
