Best cam for 383?
Old Dec 5, 2003 | 12:11 PM
Gripenfelter's Avatar
Best cam for 383?
I'm helping a friend decide on parts for his 383.
This is going to be a mostly track car with some street duty.
Right now he has stock ported LT1 heads but might go with AFRs later if need be.
What would be a good cam profile to go with?
Emissions is not an issue.
Here's what he has so far:
3200 stall
Jet Hot Long Tubes
3.73 gears
36# injectors
383 rotating assembly.
Old Dec 5, 2003 | 12:49 PM
Camaro_Maniac63's Avatar
If you want an off-the-shelf cam, then look at stuff with big lift and healty duration. GM 847 comes to mind...
But since it is going to be mostly a track-car you say, I would get the heads flowed and get a custom cam. So you might want to wait on the cam till you guys get the AFR heads. Unless he doesn't mind spending the money on a cam twice. Good luck.
Old Dec 5, 2003 | 01:26 PM
What are the specs on the GM 847 cam?
Old Dec 5, 2003 | 02:40 PM
got_hp?'s Avatar
234/242 .... 575/595 lift w/ 1.6rr.
Old Dec 5, 2003 | 02:50 PM
madwolf's Avatar
Another vote for custom cam. I've heard a lot of good things about Joe Overton's cams. Might want to contact him for an opinion....
drptop70ss
Mar 26, 2015 01:50 AM
transam_388
Mar 15, 2015 11:53 AM
Killer94z
Jan 13, 2015 12:06 PM
Queens94z28
Nov 20, 2014 06:03 PM
