bellhousing help
all right I just got my transmition out and started to take the bellhousing off but it wont move. I took all 6 bolts out, and tryed to prey it with a crow bar and it still wont move. Could it be just stuck or is there a bolt That I dont see. I just dont want to break the bellhousing.
James |
A4 or M6?
m6
Have you pulled the clutch fork out?
yes the whole transmition is on the ground and the dust cover is off the back
My bad, I misread your post, I thought it was still in the car. When I did my clutch I never pulled the bell housing, but I would assume that you could pry on it. There's no sealing surfaces right?
not that I can see I hove no clue
From what I remember, nothing seals to it, it's just there to basically encompas the clutch and to hold the tranny to the engine. I would check for a gasket hanging out, if there are none (which I don't think there are) pry away.
thinks a lot for all your help
Re: bellhousing help
Originally posted by jeepz28 ...... I took all 6 bolts out, and tryed to prey it with a crow bar and it still wont move. Could it be just stuck or is there a bolt That I dont see..... |
| All times are GMT -5. The time now is 08:00 AM. |
