Battery keeps dying after being idle for more then 5 days
Well, my Optima Red Top battery seems to loose charge after about 4-5 days if I dont drive the car. If I charge her up with a battery charger the battery works fine and the car can be started. Also, if I drive her every few days the battery seems fine since my 200Amp alternator seems to bring the charge back up.
Now, the real question is how do you track down which peice of equipment is drawing all that current to kill the battery in 4-5 days? Or could it be the battery that cant hold the charge?
Originally posted by NineSevenWS6
Do you have a multi-meter? The manual should give you a run down on how to do a 'draw test'. This will help you track down a faulty circuit.
I got a multi-meter!
Now the real question is where do I start checking for current draw and what I do reference off of?
Un bolt the - battery terminal, put - to that and + to the + battery lead. Then you should see a draw, start pulling fuses till it stops. Its been a while since Ive done this, but Im sure thats how it goes...
Or do you mean to put the meter on the Amps setting and put the meter inline with the main ground? So, it would look like this
(- neg battery) -> (-) Meter -> (+) Meter -> Existing (-) batter cable terminal
If I remember right the max my meter could take was either 2Amps or 10Amps max. Do you think I will be drawing more current then this if I run the meter inline with the negative battery terminal?
Originally posted by joeSS97
I am thinking it is your battery.
Sorry, could have been a little clearer.
Unbolt the negative terminal of the battery, put your - multimeter lead to this. Then put your positive lead to the still bolted on + lead at the battery. You might notice a slight drain, it will usually trickle down slowly. This is where another set of hands come in handy. Start pulling fuses till the voltage stops dropping. You can replace a fuse after you find out it isnt the culprit. Once you verfiy the circuit, you can trouble shoot from there.
Hmm... let me see if this is right.
***Multimeter set to AMPS (Current)
(-) term of batt (cable or term?)-> (-) multimeter -> (+) multimeter -> (+) term of batter (cable or term?)
How do you create a ground if your your negative battery term isn't grounded if the (-) side of the multimeter is connected up to the negative lead? I must still be reading your description wrong cause what it sounds to me is you just created a loops using the positive term. Where is the ground that you need to read voltage? If the meter is inline with say the positive or neg. term then it would be reading current draw but if were just running it parallel we would be reading voltage. Care to explain it a little bit more for me?
But if nothing is connected up to the negative side of the battery terminal how do the electrons flow from one terminal to the other?
It doesnt matter if the negative terminal cable is connected to the chasis because no electrons would make it to the negative term on the batt.
Am i misunderstanding something? Anyone else want to chime in and clear this up for me? Thanks!
Gtpguy
Jan 26, 2015 04:50 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
