Bad O2??
Bad O2??
Could a bad rear O2 sensor cause my car to run at 18 volts? I have tried everything, replaced Battery, altenator and voltage regulator and still having same problem.
I need serious help, asked all my car buddies for help on this and no luck.
is that 18v the reading on your guage on the instrument panel?. maybe its faulty if its the only thing reading 18v. Use a DMM or something to test it, see if you get a different reading. I figure running at 18v. you'd be fryin things alot, like your battery.
colts0455
13
Aug 7, 2015 09:15 PM
zajones
Jul 30, 2015 02:18 PM
