Bad day at the dyno le2 combo results
Old Jul 23, 2008 | 05:36 PM
Billet ss's Avatar
94 camaro z28 le2 combo,30 lbs fords,255pump,58mm asm t/b,passetters,flowmaster catback,3400 edge,12bolt 3:90 gear.
A/f ratio was about 14.2 across the board,we added fuel only to see it wasnt helping,(fuel pressure was at 46psi) found out that the volts were reading low(12.5 volts) it has 14.00 volts at the battery(which is in the back) and alt,but only 12.5 volts after the pcm,we checked it at the injectors it was 12.3 volts we then tryed to boost the volts by hooking up a charger to the post and it had 13.6 volts,so we made another pull and the a/f went to 13.00
I also has 2 codes 33 and 64
Old Jul 23, 2008 | 06:09 PM
MeanGreen97Z's Avatar
Where are your graphs? What was the power made?
Old Jul 23, 2008 | 06:22 PM
Billet ss's Avatar
anybody?what can I do to fix this?
Old Jul 23, 2008 | 08:07 PM
ricehammer's Avatar
What gauge wire are you running from the battery to the distribution block up front? If it's not large enough then line drop (voltage drop in the line) may be your problem. Also check your ground connections.
Old Jul 23, 2008 | 08:37 PM
Billet ss's Avatar
the wire is either 2 or 0 gauge,it made 351hp304tq when the a/f was 14.2 then when to 359hp316tq when the a/f was at 13.0
I went to the dyno a few months ago and was told I was lean with a a/f of 14.5-15.4 but it made 363hp366tq?
Old Jul 23, 2008 | 08:41 PM
Billet ss's Avatar
grounds seem good I just added another from the motor to the frame,the one on the motor mount to the battery,I thought it should be to the motor? I just tryed cranking it and the volts dropped below 11.0 until it started? It doesn't have a problem starting or holding a charge,I just started it after sitting 3 weeks.
Old Jul 23, 2008 | 10:02 PM
Find out what gage the wire is.
Old Jul 24, 2008 | 11:17 AM
Billet ss's Avatar
Its 1 gauge,I noticed that the charging system was at 12.? even before the battery in the back,and its a new redtop optima,what can I do to bring the volts up?
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
cheapchevy
Apr 8, 2015 08:48 PM
canbaufo
Parts Wanted
Feb 21, 2015 11:51 PM
jb4xx
Feb 2, 2015 10:00 PM
Amshnock
14
Jan 18, 2015 11:47 AM
