backfiring through the intake...
Old Mar 25, 2005 | 01:08 PM
  #16
ajschult's Avatar
Re: backfiring through the intake...
Originally Posted by Pasky
Opti fell off the slot, I gaurantee it. Went through this two months ago.
http://shbox.com/ci/opti_mounting.jpg
Your dowel pin fell into '4'. That little cavity between the place where its supposed to be. The opti will fit snug and seem like it is on correct. Mine also backfired through the intake during my first cam swap. I gaurantee this is the problem.
Huh?!?! Not sure I understand this.
Old Mar 25, 2005 | 01:11 PM
  #17
Pasky's Avatar
The opti goes on one way:
http://shbox.com/1/opti_back.jpg
Where the arrow is pointing is where your dowel pin needs to go into it (not in the small rectangle its pointing at, but the slot connected to it). It goes into the slot with the small rectangle on top of it. What happened is I know its a pain in the *** to see where its going into when your installing it, is....You put the opti on and the dowel pin on the cam fell into one of this big circles. The opti will seem like it is on correctly because it will seat against the block just fine. I bet your car sounds like it wants to start, fires off about 2-3 cylinders and back fires right? You need to re-install the opti and correct it. I had the EXACT same problem.
Old Mar 25, 2005 | 01:17 PM
  #18
ajschult's Avatar
I may have just found a new hero.
Old Mar 25, 2005 | 01:25 PM
  #19
wicked_95z's Avatar
Good call
Old Mar 25, 2005 | 01:29 PM
  #20
turbo_Z's Avatar
I buddy of mine installed his opti wrong like you described and it wouldnt start. We set the valves a couple times and swapped injectors and looked at every little thing till we decided to just see if the opti was on wrong and sure enough.. it was. Only difference was it wasnt backfiring thru the intake but you could hear it hit once in a while. I guess you may have the dowl in the other slot.
Old Mar 25, 2005 | 01:51 PM
  #21
ajschult's Avatar
yeah, when we installed the opti I didnt even realize that the dowel pin had a certain spot to time it correctly. I have another question though: The dowel pin was much longer than the original cam, so we ground some off. Is it possible that we ground it too short?
Old Mar 25, 2005 | 02:37 PM
  #22
Pasky's Avatar
Taken from shbox.com:
GM specs indicate that the dowel should be .620" long (protrusion from the front face of the cam) for the vented optispark. Some people have said it is supposed to be .685". Mine was actually .650" and still was in no danger of bottoming out in the optispark drive (I'm thinking .685" might be the max it could be).
Old Mar 25, 2005 | 03:41 PM
  #23
ajschult's Avatar
So is there a minimum length needed for a non-vented?
Old Mar 25, 2005 | 03:58 PM
  #24
Pasky's Avatar
No idea, I doubt you went too far because your opti is being driven and is firing off sparks. If you were too short it would not go into any of the "cavities" on the opti and the opti would not spin. Your fine.
Old Mar 25, 2005 | 04:53 PM
  #25
NightTrain66's Avatar
hopefully we have found the answer.
Lloyd Elliott
972-617-5671
Eportworks.com
Old Mar 26, 2005 | 02:15 AM
  #26
ajschult's Avatar
Lloyd Elliott
972-617-56710
Eportworks.com
I am confident that we have indeed found the gremlin in my motor.
Old Mar 26, 2005 | 07:20 AM
  #27
wicked_95z's Avatar
That can be pretty tricky trying to get it in the correct slot. Good luck
Old Mar 26, 2005 | 09:52 AM
  #28
ajschult's Avatar
Thanks, I'll be heading home tonight to give it a try.... Fingers are crossed.
Old Mar 26, 2005 | 09:55 AM
  #29
ajschult's Avatar
Are the dowel pins on most cams just a piece that threads into the cam or is it all one ground from one piece of metal?
Old Mar 26, 2005 | 10:18 AM
  #30
simple's Avatar
the pin is pressed in
they are a mother****er too get out (from my experience)
sometimes a pair of thin needle nose pliers to grab the back of the opti that sits over hte dowel pin is the easiest way too move it around to get it too seat corrsclty on the dowel pin
just start by lining up the rectangle in relation to the dowel pin before you put it on
physically hold the opti like you are putting it on and go "ok the cam dowel is at 9 o'clock...so i will rotate the opti rectangle too 9 o'clock also before i try to slide it on" (those sre just example reference points, it doesnt have too be at 9 0'clock)
