Backfiring
Old Aug 1, 2003 | 03:23 PM
93ZM6Tally's Avatar
Backfiring
My car has always backfired, (Gurgled), a little when I let off of the gas. I have Hooker LTS and an off-road pipe and Hooker Cat-back. The other day on the freeway I was cruising at high speed with a bud and he tells me that I backfired and a three foot flame shot out of my rear tailpipes. Here is the question.
1. Backfiring has lately gotten worse. What causes backfires?
2. Car doesn't idle at as high an RPM, I'm down around 600 RPM now used to be about 800-900 and car appears to be stall prone until it warms up. What controls idle speed?
I have recently replaced the stock coil with a Crane unit because my stock coil was breaking up at high rpm. Other than that no significant changes.
1993 Z28 M6 Ported Heads, 58MM TB, 1.6rr, cc305, PCMForLess tuning, Hooker LTs w/ off-road and Cat-back. Thanks.
Old Aug 2, 2003 | 01:12 PM
93ZM6Tally's Avatar
Re: Backfiring
Update:
Now it appears that I'm significantly breaking up when the car is warm over 5000RPM. Is it possible that I've already wasted this coil. What else would cause these symptoms.
Old Aug 2, 2003 | 07:43 PM
HK45's Avatar
Check your wires, if there good, Id say Opti.
Old Aug 3, 2003 | 12:12 AM
D James's Avatar
I would call around to different auto stores and see if they will lend out a diagnostic tester so you can see if you are throwing any codes, The 2 near me require a deposit and then give your money back upon return of their tool. They work great, tell you everything. The new coil could have gone bad, but doubtful, you have other issues. Have you changed your O2's this might cause an overrich problem. The opti will make your car backfire if its going and cause some of your symptoms, also it will make the car harder to start, or it might stall out on you, and the opti does affect low end RPM
Old Aug 3, 2003 | 08:22 AM
Since he has a 1993, he can still flash any trouble codes with the SES light.
Old Aug 3, 2003 | 08:27 AM
Cmr0z28's Avatar
holy sh*t man, 3 foot flames, thats a good way to stop someone from tailgating you!
anyways, that "gurgling" noise, i thought it was normal because my car does it.....if im on the gas for any period of time and i let off of it, it makes the "gurgling" noise and when i slowly press the gas pedal again, it backfires but i duno man its not like a misfire or anything......weird
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
tommalcolm
Sep 11, 2015 03:39 PM
Dzmaro
Jun 19, 2015 11:38 AM
Chet1185
May 10, 2015 09:24 AM
