ARP main stud help...
Old Mar 19, 2007 | 02:04 PM
  #16
mkent's Avatar
Originally Posted by cehan
I had the same problem with my 4 bolt mains (studs, actually)...no way to use the stock windage tray. That's why I went with an aftermarket pan, mainly to get a windage tray (not to mention that the trap doors to keep the oil near the pump pickup).
I PM'd you on this statement.
Old Mar 19, 2007 | 02:38 PM
  #17
1racerdude's Avatar
Get ARP studs for a 400SBC and they will work.
Old Mar 19, 2007 | 03:37 PM
  #18
mkent's Avatar
You're sure about this? I will certainly go with these if they are cheaper than those Miloden's from summit.
Also, there are 2 different listings for me to choose from out of the ARP catalog:
400, with windage tray #234-5606
400, w/windage tray and w/3" outer stud #234-5607
Do you know which of these is appropriate for the LT1?
Michael
Old Mar 20, 2007 | 11:20 AM
  #19
1racerdude's Avatar
They will work,have used them before.
Don't know offhand which is correct. Do your old ones have a 3" long outer bolt to bolt on the baffle?
Old Mar 20, 2007 | 11:58 AM
  #20
mkent's Avatar
I think they did but I don't remember. I gave those to the machine shop months ago so they're gone for good.
I called ARP Tech Department and they said they don't make the bolts needed for the LT1. I asked him about using the 400sbc ones and he knew nothing of it.
I trust you on this and it is the way I would like to go, but I need to know which of the 2 part numbers it is.
Is it possible for you to easily figure out which you used? If not I may just order 3 of each and see if I can send back the 3 I don't use.
Old Apr 3, 2007 | 04:35 PM
  #21
Steve in Seattle's Avatar
Question
Anyone ever sort this out?
I'm looking at just getting the Milodon kit and storing the 3 others for later use.
I have 4-bolt mains with ARP studs... I'm hoping the Milodon-ARP combo won't through off my fang sway.
Old Apr 3, 2007 | 05:18 PM
  #22
WS Sick's Avatar
When I used the ARP ss
horter studs I seated them by hand ,torqed thecaps into place
,installed the rods with a junk set of bearings, set the pan up about .050 from the ceank, then butchered it to fit with .050 clearace on each rod hole.
Old Apr 3, 2007 | 07:22 PM
  #23
1racerdude's Avatar
Does your block have 3" long outer studs?
If not get the other part number.
Old Aug 2, 2007 | 09:38 PM
  #24
TravisA's Avatar
wrd1972, what did you end up doing? Using the Arp's or did you go with the Milodon studs?
I'm at the point where I need to buy the milodon studs or adjust the arp's to work with the stock windage tray.
Old Aug 2, 2007 | 09:46 PM
  #25
camaro81's Avatar
I just posted up another thread askin a few questions about these studs. I'm wondering if you cant just leave the stud a bit farther out of the hole to get the extra length to secure the tray.
Old Aug 3, 2007 | 07:26 AM
  #26
wrd1972's Avatar
One of the guys here on the board sold me three new Milodon studs that I used with the windage tray. I would suggest doint this even if you buy the full long stud kit and sell the others off, there is no way I would trust those shorter ARP's.
Old Aug 3, 2007 | 03:03 PM
  #27
TravisA's Avatar
Good deal that's what I wanted to know....thanks.
Old Sep 18, 2007 | 10:51 PM
  #28
seawolf06's Avatar
Did anyone figure out which of the two 400SBC ARP kits is correct for the stock LT1? What outer stud are they asking about??
Old Sep 19, 2007 | 12:30 PM
  #29
Kevin Blown 95 TA's Avatar
I used the Milodon studs also. As for thread engagement, a good rule of thumb for a screw into steel or iron is that you want about 1 1/2 times screw dia to thread into a hole for max strength. Naturally, this changes with the type of material you are screwing into.
Old Sep 19, 2007 | 01:04 PM
  #30
seawolf06's Avatar
So I could use the ARP hex head bolt kit and then just replace three of the bolts with three of the Milodon studs? If this will work, can anyone sell me just three studs? Thanks.
