Anyone using a Lokar throttle cable?
Old Sep 5, 2003 | 07:02 PM
madwolf's Avatar
Arrow Anyone using a Lokar throttle cable?
I need a replacement for a stock throttle cable and was considering a Lokar. If anyone is using one, which part number do you have?
Thanks.
Old Sep 6, 2003 | 07:32 AM
97FormulaWS-6's Avatar
I'm running one...
It's the TPI one.. P/N I don't remember..
But you're going to need 2 stainless washers about 1.5" in diameter with a 1/4"? hole to adapt it to the firewall; one washer on each side of the firewall.
Also, you're going to need the black clip off of the original cable where it attached to the gas pedal.
Other than that.. the hardest thing is setting up the length of the cable, takes 2 people... one to hold the pedal to the floor, the other to hold the TB at WOT and tighten the cable.
AtlasXVIII
Aug 24, 2015 11:41 PM
Aug 24, 2015 06:41 AM
Slayer
Aug 17, 2015 03:55 PM
detroitmuscle
Jul 31, 2015 04:21 AM
88IROC_Z
Jul 22, 2015 11:38 PM
