CamaroZ28.Com Message Board
-   -   Anyone run this high torque starter? (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/anyone-run-high-torque-starter-390783/)
CANTONRACER Aug 17, 2005 07:16 AM
My flexplate is 168 tooth TCI SFI unit.
Stock starter not gonna happen so I am looking at this unit:
Starter
Just curious if anyone is running this unit.
I also have a Canton oil pan and Kook's 1-7/8" headers...so clearance is important.
Injuneer Aug 17, 2005 10:10 AM
Re: Anyone run this high torque starter?
Check out this starter at JEG's:
555-10001
This is the same starter that they used to sell under the "CVR" brand. Now they sell it as "JEG's". Works with both 153 and 168 tooth ring gears, rotates into multiple positions to clear headers. Starts my 381 stroker smooth as silk. And under $150.
CANTONRACER Aug 17, 2005 09:29 PM
I just ended up getting this one:
6.5 lbs & small
It came with bolts and shims...also put me over the mark to get a $40 Summit gift certificate yet again...had only 10 in the last two years... me = :D wife = :confused:
