anyone replace they PCV valve? need help
was putting in a new pcv, and it wont sit flush against the intake manifold.
i have the right part number, it matches the one that came out.
the original was snugly fitted into the hole, and mounted flush up to the ring around the pcv.
the new one doesnt feel snug, and if i pull lightly on the pcv line, the valve starts to slide out of the manifold.
will this cause problems? im guessing it could suck air in around the valve if its loose.
When I replaced mine, it did the same thing. After putting both PVC's up next to each other, it became apparent they weren't exactly the same, but the new one was the right one. I ended up having the parts store cut me a piece of vacuum tubing just a little bit longer than what was on the car and I had no problems with it coming out. Hope this helps.
it seems to run fine at idle............i even pulled the pcv completely out while it was idling and nothing happened.......
im just concerned about anything happening while im driving or at WOT.
anyone know for sure?
