CamaroZ28.Com Message Board
-   -   Any Ideas? (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/any-ideas-189159/)
c0rey Nov 3, 2003 10:04 PM
Any Ideas?
We got the exhaust hooked up to the headers. We replaced the coil. We checked all the wires even though they are new. It has new Accel Plugs. We ran a code check and it pulled. It pulled O2 problem, EGR problem, and knock module in bank 1 and 2 it said. It still cuts out most of the time when you floor it, or its under a load.
Any ideas?
I Have left to swap ICM and Opti
shoebox Nov 3, 2003 10:26 PM
You need to post the actual code numbers.
"knock module in bank 1 and 2" makes no sense at all. :confused:
c0rey Nov 3, 2003 10:29 PM
it was knock sensor in bank one and two i didnt write down the actaul numbers.
shoebox Nov 3, 2003 10:37 PM
:D Sorry, it still makes no sense to me. Sometimes various sources of code explanations can be incorrect, that's why the actual code numbers can help.
c0rey Nov 3, 2003 10:38 PM
thats what the scanner said any ideas when its cutting out still?
