CamaroZ28.Com Message Board
-   -   Any drawbacks from removing AC system? (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/any-drawbacks-removing-ac-system-113933/)
DarkHorse Apr 29, 2003 01:31 PM
What are the disadvantages from removing the AC equipment? I'm obviously not worried about the "no air" drawback, are there any other complications from removing this?
BPS Apr 29, 2003 01:38 PM
None that i know of - I'm happy i did it as it cleans up the engine and make plug assess a lot easier - all you need is the ac delete pulley and a couple of tools.
JD30thZ28 Apr 29, 2003 01:39 PM
I removed mine over this winter and have not had any problems and can't think of any possible problems. Only thing I had trouble with was getting the right size belt to go with the A/C delete pulley. Some guys have had the stock belt work although mine was kinda of lose so I just got one which was 1/2" smaller.
DarkHorse Apr 29, 2003 01:53 PM
Are there any write-ups on what all to remove? Shoebox? Anyone? thanks
trax Apr 29, 2003 02:43 PM
In a nutshell:
--Have a shop drain the system. Note: do not wear clean clothes when you drive in and ask for this. Looking like hell will usually get you a little discount ;)
--Locate the heater core assembly on the passenger side of the engine bay. Unscrew the two braided hoses sticking into the metal "block".
--Pull the soupcan-size accumulator
--Unbolt hoses from rear of AC compressor
--Unbolt hoses from AC condensor (by radiator) and remove condensor
--Remove serpentine belt, unbolt AC compressor. You will have to shake it like a mofo to get it out and around the sway bar. Trust me, you can do it without removing anything else. But you will have to fight it a little.
--Install 1LE AC delete pulley, reinstall serpentine belt, go driving.
I might have missed a couple finer details but that's what I remember off the top of my head.
DarkHorse Apr 29, 2003 06:39 PM
Perfect. Thanks, I plan on removing the sway bar as well so hopefully it will be a little easier.
ramair96ws6 Apr 29, 2003 07:20 PM
it will be hot in the summer :D:shock: :shock:
Steve
95_RipperZ Apr 29, 2003 07:55 PM
Make sure you get all the bolts. There are 3 big ones on the front and 3 bracket ones in the back of the compressor. They are a little hard to get to also with everything still in place. On one, I couldnt get the ratchet to move so I used a small impact I had to get at it. Otherwise I dont know how I would have got it. The ratchet kept hitting stuff and wasnt turning enough to click. Not hugely bad though.
DarkHorse Apr 29, 2003 07:57 PM
Steve
I'm from Florida so the heat and humidity doesn't bother me. I hate AC in a car, I like windows down and tops out. Yeah, i'm weird :p
Thanks Ryan. Hey how's Jeff's car coming along? Ready to hit Big Shot?
Dr.Mudge Apr 29, 2003 08:16 PM
Depending how old your old belt is, you may need a new one, mine had too much slop in it.
94FlamdS10Blazr Apr 29, 2003 11:27 PM
yeah there is one drawback= the chicks might not wanna ride with you
DarkHorse Apr 30, 2003 08:49 AM
LOL
Married and my wife is very proficient with a handgun, chick might not wanna ride with me. :D
