anti-seize on header bolts??
I know its a stupid ? but is it needed or what?? thanks guys
Just get stage 8 header bolts, makes life simple!
I used but and a couple of them still loosened up. Just be sure to check them about a week after driving.:)
The mechanic that did my motor used it on the header bolts, but said they will most likely loosen up anyway.
Definately use the antiseize. You are putting two dissimilar metals together. The stage 8 bolts are a good idea.
Use antisieze, it makes it so much easier to remove the bolts when you have to replace a gasket.
| All times are GMT -5. The time now is 08:09 AM. |
