Another question, optispark not sitting flush (pic)
Old Oct 25, 2007 | 01:57 PM
urbaNHunter44's Avatar
I'm putting the opti on and the mounting arms won't sit flush against the timing cover. There's about a millimeter gap. I can get a pic.
The dowel pin is slightly shorter than stock (verified with clay) and it is definetly in the right hole. Is this normal?
Old Oct 25, 2007 | 02:14 PM
2QUIK6's Avatar
Mine does that, but with a quick hit with the palm of my hand in the center of the opti it pops right into place flush. I think its the o-ring that is not quit in place on the shaft without the "tap" of the palm.
Old Oct 25, 2007 | 02:17 PM
windsma's Avatar
Vented? sig says 97'
My non just popped right in first try yesterday, kinda make me unsure it will work.We have keyway shaft though.
Old Oct 25, 2007 | 02:18 PM
i gave it a love tap and it worked. thanks man
with any luck this beast will be alive tonight
Old Oct 25, 2007 | 08:01 PM
cruzinMaroZ28's Avatar
if i were u and i talk from experiance i would start put it back togeather except for the water pump and try to start it to make sure every thing is good i no i would of saved me alot of time and head ace
HectorM52
Jan 30, 2015 11:34 PM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
FIREBIRDMARK1
Jan 7, 2015 03:36 PM
cmdeshon
Dec 27, 2014 10:06 AM
Injuneer
Dec 15, 2014 09:36 AM
