Aiming TA headlights
The headlights on my car are shifted toward the passenger side, and only light up right in front of the car...No distance to them whatsoever. They're as bright as a headlight should be, just out of alignment. How do I get them aligned? Are there screws to do it?
I guess there's a reason I put 'stupid' in my screen name...
you are correct.. these headlights use screw. i think you must do this...
- park the car 20 feet away from a wall or garage door and open
the hood, make sure your head lights are on.
- Once the headlights are up, remove the 2 or 3 screws on the
sides of the headlight housing, these screws attach the black
side cover to the assembly. after you remove the black cover
you will see the 2 screws that adjust the headlights.
- now you can aim them
good luck, and remember any damage you cause is not my fault
jackpawt883
Sep 10, 2015 08:53 PM
Aug 17, 2015 09:50 AM
Henson071
Aug 4, 2015 09:32 AM
