CamaroZ28.Com Message Board
-   -   AFPR and injector sizing question (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/afpr-injector-sizing-question-215935/)
GREGG 97Z Jan 22, 2004 11:18 AM
I noticed in another post here that someone mentioned increasing fuel pressure to the fuel rail could help make up for undersized injectors. I have the stock 24# injectors and based on my last dyno (327rwhp with a miss at the time that has been corrected) and current trap speeds (115) I beleive it may be making around 335-340rwhp. I have installed a 255lph Walbro pump but I am still using the stock FPR. I thought the stock 24# ers were ok for a stock head, hotcamkit/bolt on car and I hadnt planned on replacing them until I went with a bigger cam/heads but that post has me wondering if I could be pushing the duty cycle too high.
My question is would it be a good idea for me to increase the fuel pressure at the rail in the meantime with an AFPR (which I have had but not installed yet) by a few pounds to help reduce a possible high duty cycle or is that just a bad idea without knowing the exact duty cycle (not sure how to calculate it honestly). Last time I checked it was at 43 lbs at the rail with just the key on. Thanks.
QCKZ28 Jan 22, 2004 11:35 AM
you have to program the injector constant in your PCM to 30#
and increase your fuel pressure to 58psi.
yes it will work, but this is just a bandaid.
you need bigger/better injectors...
#30 SVO would work perfect.
jesse
QCKZ28 Jan 22, 2004 11:38 AM
here is a thread i started:
http://web.camaross.com/forums/showt...=fuel+pressure
jesse
GREGG 97Z Jan 22, 2004 11:52 AM
I kind of figured it wouldnt be a good idea to just increase the pressure to make up for it but wanted to check. Thanks for the info.
QCKZ28 Jan 22, 2004 11:56 AM
i ended up going with a bigger injector too :) and reducing the fuel pressure.
jesse
