Adjusting Idel
Hey I was wondering if I can adjust the idel manually or do I have to do it through the pcm. I have the cable and laptop just need a program to do it. Let me know.
Re: Adjusting Idel
The PCM controls idle based on the idle speed programmed in the tables. You need software to alter it. You could open up the throttle blades and increase it, by opening the blades until the IAC counts bottom out at "0", but that's not the best way to do it. You would need a scanner to know when the IAC had bottomed out, and to make sure you hadn't screwed up the closed throttle TPS voltage by opening the blades too far.
Re: Adjusting Idel
what about that screw on the TB where the throttle rests on...cant that be brought out a lil bit?
Re: Adjusting Idel
I just noticed the screw thanks.
Re: Adjusting Idel
Instead of hacking things up, why not figure out why its idling slow, and fix the problem the right way, rather than cover it up? |
Re: Adjusting Idel
Free scan can adjust idle at least on a '95. It is free also. Do a search under freescan. |
Re: Adjusting Idel
Mine idles at about 1000 rpm at a redlight and always has. I would like to lower mine just a tidbit or should i not touch it?
Re: Adjusting Idel
Stock programming for the M6 cars is 800rpm. The stock tach is typically off by reading 100-200rpm higher than actual. Your engine may be at the correct idle speed. Only way to know is to put a scanner on it and read the RPM from the PCM.
| All times are GMT -5. The time now is 08:55 AM. |
