AC Delco PF25 oil filter not available? PLus a ? about serpentine belt
Old Apr 2, 2003 | 06:12 PM
snksknr94's Avatar
I remember reading a couple months ago that the PF25 Delco filter that the LT1 uses was no longer available. I went to the parts dept. today at my work to get a filter for my oil change, and sure enough we don't carry it anymore. It has been replaced by the PF454. I went ahead and bought the PF454 but it is a lot shorter of a filter than the PF25 was. Is anybody running this filter, or should I just go buy a different companies that is the equivelent of the PF25. I ran the mobile 1 filter a couple of times but they always leaked. I've had awesome luck with the PF25, and always got it for a good price, anybody got any oil filter reccomendations? The longer filter is out of the question, it won't clear my headers. Also, I picked up a replacement serpentine belt and the parts guy said that there are two different ones available. The one I got is part # 88986810 anybody know if this is the right one, or the length of the right one. I think the one I picked up was 163 mm, and he said the other one was 110mm. Thanks!
Old Apr 2, 2003 | 06:59 PM
ShelbyZ28's Avatar
Go with PF35 or PF1218. Both fit and are longer filters. The work on our cars just fine plus you get the added filtering from the longer length. The PF1218 has an antidrain valve as well. This is what I use and it works great. Hope this helps.
Bryan
EviLBoX's Avatar
I was an avid AC Delco user too until they became unavailable. I didn't really want to pay $10 for a Mobile One oil filter and I've heard bad things about Fram, so I picked up a Bosch (sp?) for $5 from autozone and it seems fine. I can't use the longer AC Delco filter either, it won't clear my headers.
Old Apr 2, 2003 | 07:14 PM
Blk94Z28LT1's Avatar
i'm using the PF-454 seems to be fine. I will only use AC oil filters on all of my GM cars. Our 99 Yukon 4WD uses the small PF-51 and it's a 5.7 liter. No problems with it.
Old Apr 2, 2003 | 11:27 PM
snksknr94's Avatar
Bryan
You'll notice I said I can't use the longer filter, as it won't clear my headers.
Anybody got any ideas about the belt?
Old Apr 3, 2003 | 12:03 PM
ShelbyZ28's Avatar
Opps sorry about that. I must of quit reading before I got to that. What kind of headers are you guys running that don't let you run a longer filter?
Old Apr 3, 2003 | 08:00 PM
snksknr94's Avatar
FLP longtubes. Somebody has to know the right part # for the serpentine belt.
Old Apr 3, 2003 | 08:18 PM
OBE1 95Z28's Avatar
I'm running the Goodyear Gatorback belt, P/N 6PK1630.
Old Apr 4, 2003 | 03:20 AM
bp's95formula's Avatar
are you running stock pulley's? Go to pepboys, 640K6 belt.
Aftermarket pulley's, 590K6. (march pulley set)
HectorM52
Jul 30, 2017 11:46 AM
Dmonty
Jun 2, 2015 11:19 PM
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
grabbem88
Feb 23, 2015 09:41 PM
97 RedSS
Jun 10, 2003 07:58 PM
