AC Delco Oil Filter?
I just put an AD Delco filter on my car, if was PF454 I think, but I took off a fram, which I normally get, and the AD was considerably smaller in size. Is this the right filter? I got the one it told me in the book, but it just doesn't look right. It barely sealed on the car...
Re: AC Delco Oil Filter?
PF454 is the correct filter. If you want an AC Delco filter that is a bit longer like the old PF25 model, the new filter is the PF1218. The 1218 is the filter I have been using with no problems.
Jeff
Jeff
hmm, I work for GM and I was unaware of the 1218 fitting! I heard somewhere that it didn't work, but if you are using it with no problems, then I just may start! Nothing wrong with a little more filtering area!!
Thanks guys, I was just a little worried because it looks like it barely seals off where it hits with the car.
I just might try out the 1218 next time though. The fram just looked like it fit a little better.
Jul 4, 2005 05:00 PM
