Abs Inop Code: C1286
Old Aug 15, 2003 | 12:36 PM
Hyperspeed97z28's Avatar
Question Abs Inop Code: C1286
OK,
So I finally got around to the ABS INOP light I've had for quite some time now... I had my friend scan this at the lil shop he works at with a snap on scanner... I have no codes what so ever in the abs system other then this "C1286" which says "ABS Turned on Red Brake Light" I have no clue as to what the hell this is... Can someone help me please... This is the ONLY CODE.....
Please help, I'd like to make this ABS INOP light go away.....
Old Aug 15, 2003 | 01:03 PM
Shoebox, where are ya buddy?
I'm thinking your gonna be the only one with an answer for me....
Old Aug 15, 2003 | 01:39 PM
ATMINF's Avatar
Check to make sure that you plug wires are not touching the brake stuff. I know my plugs were touching my brake lines (the hard lines on top of the motor and drivers side)and it caused my ABS to act up. After I got the plug wires moved the ABS worked great. Good luck.
Old Aug 15, 2003 | 01:58 PM
C1286 is normally a history code and just for information purposes. Another ABS code would likely set it off, but if there were no other ABS codes present, just clear the code from history and drive on.
Old Aug 15, 2003 | 07:53 PM
thats the thing... the code wouldnt clear... ??? we tried a few times... what would trigger only that code??
Old Aug 15, 2003 | 08:00 PM
93formula's Avatar
burnt out brake light. my buddys car had the abs light on after he replaced the bulb it went away. might have been the same code.
Old Aug 15, 2003 | 08:07 PM
burnt out brake light? all my light look like they should? i dont know what one to replace... i just wanna get the code to go away and that damn light off
Old Aug 15, 2003 | 08:10 PM
93formula's Avatar
his was the center one that was burnt out.
Old Aug 15, 2003 | 08:17 PM
mine doesnt appear to be burnt out though. your suggesting i replace the bulb anyways? is there more then 1 in there?
Old Aug 15, 2003 | 08:26 PM
93formula's Avatar
there are two bulbs but if there working then your problem may lie else where.
Old Aug 16, 2003 | 08:56 AM
Shoebox..... what triggers this code? what do I look for ?
Old Aug 16, 2003 | 02:44 PM
Black_Z28's Avatar
Your blinker would flash pretty quickly if you had a burnt out bulb too.
Old Aug 16, 2003 | 03:49 PM
Other codes trigger it. If you had no other codes, I don't know what to tell you.
Old Aug 17, 2003 | 08:26 AM
This Sucks!
Old Aug 18, 2003 | 09:49 AM
Does anyone know what to look for with this?
IndyZman
Oct 22, 2015 02:17 PM
RobFlag
Aug 29, 2015 11:40 PM
TGGodfrey
Aug 17, 2015 08:43 PM
tnmotown
Aug 10, 2015 11:52 PM
realistyc
Jul 28, 2015 07:32 PM
